After driving on the highway,Or some dodgy traffic work, I'll pull up to a stoplight and I will get a heavy shaking/vibration in my car. Its bad enough that the car shakes/vibrates. I wonder if the people around me can hear/see it lol. If I put it in neutral, it lessens or goes away. But if I put it in drive it comes back immediately. I have an automatic FYI. Any ideas?
help with a weird issue.
Re: help with a weird issue.
Automatic transmission?
Sent from somewhere west of here via Tapatalk!Ian
That is a new one on me?Last edited by Festevil3; 02-14-2013, 05:59 PM.Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
i'm betting its a sympathetic vibration from the low idle speed....Trees aren't kind to me...
Originally posted by FestYboy View Posti'm betting its a sympathetic vibration from the low idle speed....Trees aren't kind to me...
^ the converter spins at all times (attached to engine), it wouldn't matter if the car was in gear or not as the converter spins the pump at all times. and IF it were the converter, the vibration would not be intermitant.Trees aren't kind to me...
check your mounts.Trees aren't kind to me...
if the TC is bad (doubtful), currently there is no easy automatic alternative other than another unit. the GL4A-H would be the easiest auto swap, but they are RARE. then there's always a manual swap...
start looking at OTHER options for your symptoms.Trees aren't kind to me...
