If you have 2 TPS's from similar cars but one is a 3 wire (auto) and one is a 4 wire (manual), can you just remove the bolts holding the 3 wire TPS to the throttle body and pull the TPS off and put it on the other throttle body where the 4 wire TPS was removed from?
Are there any things to watch out for when doing this?
