Originally posted by koRnhead
Festiva Thermostat Replacement
Originally posted by koRnhead View PostNot sure about that. Mine had a flush valve. But my dad's didn't....either way pretty easy to get back thereSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Small dirt and debris can enter the blower and be blown forward into the heater core. There is no access plate to clean the fins on a Festiva heater core. It is tucked away inside the very bottom of the blower assembly. It is a major job to remove the blower assembly, open it up, clean it and reinstall it again. That is why I installed a cabin air filter, so I would never have to do that job again. Read my thread about it. Don't park under trees with small leaves, pine needles, that are budding in the spring and have debris fall into your plenum in front of your windshield. It will dry out and get pushed into your ventilation duct. It will end up in the fins of your heater core, unless you have an A/C condenser to intercept twenty years of dirt and debris.
If you leave all that debris in your plenum, it will retain moisture and rust out that seam toward the corners. Especially right over top of the wiring harness, where it enters the firewall. You would not believe how much debris I had to vacuum out of my Festiva's plenum when I first bought it. It must have been an inch deep.Last edited by bravekozak; 02-25-2013, 10:08 AM.
Originally posted by Flw Sock View PostI think it is stuck open, I never get any hot air. I'll let the car idle for an hour, then turn on the heat for 2 seconds and it becomes cold again. The engine never gets hot, even after driving for two hours with the heat off.
**NOTE TO EVERYONE. IF YOU USE RTV (THAT BECOMES YOUR GASKET). YOU DON'T USE RTV WITH A GASKET**
I work in the gasketing business and I have customers bring me gaskets that are leaking. I find that they have RTV on them and explain to them that the RTV was the reason their gasket was leaking. If you have the right gasket and the right bolt load. Your gasket shouldn't ever leak.
Originally posted by Flw Sock View PostIt was just a thermostat problem. Picked one up from a local JY (a silver LX!), and installed it. Figured out that we had the thermostat angled the wrong way, which caused it to touch maybe a hairline against the housing, and crack. All systems go now though!Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Originally posted by Flw Sock View PostNot really "local" to me, but close enough.
Jack's Auto Salvage in Watertown has two Festivas. Don't steal too many goodies from me, I'm going back tomorrow!Last edited by nitrofarm; 02-26-2013, 12:28 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
