Fuel Injectors
  • Fuel Injectors
    Hey guys found our issue... No our BP isnt running again but i've finally found our injectors went bad... I have 8 extras... ALL BAD. I've never had that many bad injectors in my life. anyways I'm going to try to search around online a bit but if anyone knows what kind of fuel injector they (91 escort GT) are and what other cars they come out of I would love to know so I can get some in there... currently out of the 12 I have I have 2 injectors working with the fuel rail pulled, I tried them in all the slots so its not the fuel rail ports. Any help would be amazing, it looks to me like most of them are the same... If i can get this thing running, even if its like crap, in the next few hours we still have a chance for this race... Thanks guys
    Car #789
    Sponsors: Williams American Construction, Dewaynes Tire service, Roofing Supply Group
    1992 Festiva L - BP Swapped, Aspire Swapped, Rally America Sanctioned.
    1993 Festiva GL - 4sp Automatic and the bluest car i've ever seen...
    http://www.facebook.com/warally
    remove the injectors and run wires from the prongs to the positive and negative battery terminals, they'll click open...then spray them with something, I used carb and choke cleaner and pb blaster on a buddies injector in his minivan...it might at least get you by if you can get them unclogged?????????? hopefully that's all it is! bad gas..?!
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      Fuel Injectors
      It seems very unlikely that only 2 of 12 injectors work properly. Are you sure your getting enough pressure at the rail?
      2002 Ford Mustang GT Mineral Grey 5 spd
      1996 Ford Explorer XLT AWD White POS
      1992 Ford Festiva GL Metallic Blue 5 spd
        take a look at this way to clean your injectors. http://www.youtube.com/watch?v=7aT4S1lIBAY
          Tried to clean them, it was a no-go. Didn't make it for the race and we are ordering 4 new ones now. i had around 90 lbs or pressure at the rail since i swapped the fuel pump to a walboro 255, and plenty of fuel going through the return line. With that only 2 injectors kicked, no matter what position i tried them in, the noid light worked for each area, so i know they were trying to pulse. Oh well... Makes me sad but we'll go for another event in april...
          Car #789
            Look on the bright side; you've probably found all the broken BP injectors within a 100 mile radius and taken them off the market.
              that is a lot of head pressure for the injector to overcome
