My son and I recently purchased a 1991 Festiva with the auto retracting shoulder harnesses. The auto retract works as it should on the driver's side but does not on the passenger's side. I have pulled the track and checked out the motor as well as the limit switches and both are working fine. The motor works in both directions and the limit switches close when the belt moves into the switch. The problem is that the shoulder strap on the passenger's side goes to the "hold you in" position and will not retract when the door is opened or when the key is turned off. Can anyone tell me if this is a common problem and how I should proceed? Thanks.
Bob
Pasco, WA
Bob
Pasco, WA
