I have an 89 Festiva fuel injected automatic. When the temperature is above 32 degrees Fahrenheit it starts fine and runs fine. When it is below 32 degrees Fahrenheit it will not start. if I spray starting fluid in it, it runs just fine on starting fluid. so I figure it has to be the fuel injectors but why would they not work when it is cold? Has a new airflow sensor and great fuel pressure.
Thanks in advance!
Thanks in advance!
