Ok, so here is my delima. I have an 88 festiva L that has the 92 powertrain. it also has aftermarket ac so to say its cluttered is a total understatement. last summer it overheated and blew the deadgasket. I tore it down and the head was warped pretty bad. I had the head machined and replaced the head gasket, themostat, and waterpump while i was in it. The repair went really smooth except there were no alignment dals to hold the headgasket. Im 12k post repair and have devoloped a major oil leak (it will go through a gallon jug a week pulling 75 miles a day). it doesnt leak at idle, but if you clean everything off it looks to be coming from where the head and block mate. i know i need to tear back down and fix it right, but any ideas at a quick fix? anyone had a similar issue after a head instal? thanks
92 B3 gushing oil!!
Have you checked the torque on the head bolts? Could there possibly be one or so of them loose?Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
