This person I'm buying it from says he has worked on the top end of the motor (head, valves exc.). He says it needs a valve adjustment & a carb rebuild still. When it runs the valves knock. Would that be the case? It just needs a valve adjustment?
Also when and if I get the Festiva, I have to drive it over 300 miles to get it home. Would it be ok to drive it that far if it needs a valve adjustment?
