my seatbelt problem
  • my seatbelt problem
    92 L EFI. i finally found out why my automatic seatbelts keep blowing the fuse. before it would take a couple of days to a week for it to happen. the other day i just jumped the place the fuse goes w/ a wire and then a larger fuse and the passenger door side belt keeps trying to retract when it already was. not constantly, but it'll do it for as long as it takes to normally retract ant then stop on it's own. 30 sec. or so later it does it again and eventually blows the fuse. i tried messing w/ it manually while it's doing this and did no good. anyone have any ideas? is there something that's supposed to stop it or suppose to tell it to stop? my drivers side works perfect. also, the bad side won't retract when you open the door. sensor or something? i've looked and messed w/ some things but no luck. thanks.
    adam
    92l efi 240K+ stock
    guess nobody else has had this problem. how easy is it to replace the passenger side seat belt motor, track, etc.?
    92l efi 240K+ stock
      there is two switches on the seat belt track
      one on the A pillar and one on the B pillar
      forward stop on the A
      retract stop on the B
      plus there is a micro switch in the door latch (in the door assembly)
      then you have the control module located under the drivers seat
        thanks. gives me something to work w/.
        92l efi 240K+ stock
          could give you more , but my scanner is out of order
            no problem, at least i have something to start checking.
            92l efi 240K+ stock
              and here is a little more help:
                thanks for the info. if it ever stops raining today maybe i can get some work done.
                92l efi 240K+ stock
                  i have the same probablem. on my 91
                  but its my driver side that is crap and the passenger is good.
                  but i think it might jsut be my door switch.
                  havnt really botherd looking into it.
                  cops around here dont say anyhting as long as i have my lap belt on. wich i always do. :lol:
