OK, I am going to take the plunge and do my headgasket and water pump.
Just a few questions before I start, do I need to use a copper spray on the gasket?
Also is it absolutely necessary to have the head surfaced? I need this car fixed yesterday so I can't take anymore downtime.
With my eclipse im using a mls head gasket so both the block and head need to be a mirror finish. This is a high boost engine though (28-32psi) will this engine need at least a resurface on the head? I bout the car with a broken water pump so who knows how bad my festiva was overheated from prior owners, possibly causing the head to warp.
(I know pretty much nothing about n/a, pretty sure I already know the answer to this but I want opinions)
