just need help on this..my kia undergone just diy top overhaul..change head gasket,camshaft oil seal,oil pan gasket,valve seal, valve is ok just grind a little on the valve seat..did a leak test and the result is ok..and also change the piston rings..but after the top overhaul, run the engine and there's a white smoke on the exhaust..just a little smoke when it's on idle but when you rev it smoked but not a lot..so what i did again,adjust the valve clearance set to .008 and .010..so when it start, there is no more white smoke..test run is ok..but the next day i start the engine and just rev a little it smoked again..it could be the head gasket?my carb adjustment is 2 1/2 turns..ive checked the radiator pull out the cap and there's a bubbles going out about 3 seconds gap.. thanks guys..
blown head gasket,carb adjustment or valve adjusment?
There are several things you didn't mention doing but either way you can do checks, next time you shut the car off hot pull the plugs and see if steam comes out any of the plug holes. If it does smell it. You should be able to smell the difference between coolant, fuel or oil . Smell the smoke next time you start it.Reflex paint by Langeman...Lifted...Tow Rig
