Ac not working , b6d engine swapped aspire
  • Ac not working , b6d engine swapped aspire
    Has anyone run into this issue before when swapping an aspire . Everything else works fine , I had to install part of the inj harness to send sensor readings from manifold . I thought that would be the issue but its still not working .
    This ac was working fine before the swap so I'm certain it's something that needs connected to trigger the ecm . The dash switch light does come on but engine fans and comp has no voltage .
    Many idea would help. Thanks
    New build on the way .
    Anyone have a copy of the wiring diagram
