... If these rotors would fit on my Festiva? It has those solid stock rotors on there now.
I was wondering....
I was wondering....
1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
MikeTags: None
What do you mean?Originally posted by shadetree View PostYes ! They will fit but you have to break the bearings down !1993 Ford Festiva L blue 170,000 miles
Mike
I will be doing the Aspire swap but not now. Too much time and money is needed. I will need a clutch and some re-wiring done also.Originally posted by bobbyspider View PostTOO MUCH WORK. do an aspire upgrade and youll be set or ask about a capri brake swap. much more support here for that kind of thing
I was just wondering about those one rotors.1993 Ford Festiva L blue 170,000 miles
Mike
Questions to ask: what motor are you running and what kind of stopping power do you need? The aspire swap I have on my BP car will shut that thing down when I need it too. Another question is: what size are those rotors? I looked at the ebay add and couldn't figure how big are those rotors? I know the add says its for a Festiva but its ebay and ebay is hard to trust. If you have stock 12s or even 13s there are not too many aftermarket places that support rotors that small. Most stock rotors are bigger than our wheels now. I could be wrong about all this stuff I'm saying so maybe someone else more knowledgeable should step in from here. I still consider myself a noob here
Questions to ask: what motor are you running and what kind of stopping power do you need? The aspire swap I have on my BP car will shut that thing down when I need it too. Another question is: what size are those rotors? I looked at the ebay add and couldn't figure how big are those rotors? I know the add says its for a Festiva but its ebay and ebay is hard to trust. If you have stock 12s or even 13s there are not too many aftermarket places that support rotors that small. Most stock rotors are bigger than our wheels now. I could be wrong about all this stuff I'm saying so maybe someone else more knowledgeable should step in from here. I still consider myself a noob here.
Also it would really help if you put a location. Help could be a phone call away and God love you if your lucky enough to be by dem Florida boyz because youll have a BP or a b6t in your car before you can blink.
God bless dem FLboyz
The pictured rotors are of the 'floating' and vented type (ie for more modern cars (even including Aspires and Rios)) and not like the archaic Festy 'integral with the hub' solids. "Floaters" are held by 2 screws (which are not even essential) whereas the Festy jobs require releasing the driveaxles and pulling the bearing-filled hubs off in order in order to get at the backside rotor bolts.
Thanks for all of the advice ..... it helps!
I'm near the Cincinnati Ohio area.
Sounds like I need to get to know those FLboyZ1993 Ford Festiva L blue 170,000 miles
Mike
I was wondering....
Or you can drive over to the Indy crew.. We've got a lift now!! Take that Florida! HaOriginally posted by muleskinner View PostThanks for all of the advice ..... it helps!
Sounds like I need to get to know those FLboyZ-------------------------------------------------------------------------------------------
My Musica! Click me!
I can do that! Only a 2 hour drive instead of 6. LOL!Originally posted by Charlie1717 View PostOr you can drive over to the Indy crew.. We've got a lift now!! Take that Florida! Ha1993 Ford Festiva L blue 170,000 miles
Mike
Of course I'm offering someone elses lift to be used :p Gauge_Half_Inch just got a lift and is one of the more knowledgeable members here! Him and Dale (another member) can get just about anything done! I'm usually there just for the comic relief.Originally posted by muleskinner View PostI can do that! Only a 2 hour drive instead of 6. LOL!-------------------------------------------------------------------------------------------
I would be too! HA!Originally posted by Charlie1717 View PostI'm usually there just for the comic relief.1993 Ford Festiva L blue 170,000 miles
Mike
