Was curious if anyone knows what might be happening with my car. It's happened twice now on two separate longer trips. Both times it came one a couple times in the first 45 minutes or so and then turned off for the rest of my 2.5 hour trip. Both times there was no apparent reason. The car was acting and accelerating like normal. Both times it was at extended speeds of 55-70mph. No odd smells. No smoke. And by the time I get back home the CEL were off...so I'm not sure if I can do the normal procedures to check what codes it's throwing? Can I still check this if the CEL is off? My car is a '92 5 speed which just had it's transmission replaced around 2 weeks ago. Never thrown a CEL before these two incidents.
CEL Coming on and Turning Off
Tags: None
Somewhere to start I guess!
Looks like the Denso ones are 30 bucks. There are some Bosch ones for under 25.
Rockauto, when I got mine it was around $20 shipped with the plug.Originally posted by Prafeston View PostLooks like the Denso ones are 30 bucks. There are some Bosch ones for under 25.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Weird, the APWI O2 sensor is like just a few cents cheaper than the Denso and at a little over 3 bucks shipping they come in at 19.XX. The Denso however the shipping is nearly as much as the part at like 13 something. Makes it over 30 bucks. Is there any reason to get the Denso over the APWI?
Originally posted by Prafeston View PostWeird, the APWI O2 sensor is like just a few cents cheaper than the Denso and at a little over 3 bucks shipping they come in at 19.XX. The Denso however the shipping is nearly as much as the part at like 13 something. Makes it over 30 bucks. Is there any reason to get the Denso over the APWI?
I would have to say just from the positive feedback the Denso gets on here is why I would choose it over the APWI one, that and I believe the Denso is what came in these cars when they came out of the factory, I believe this because even my TPS says Denso on the side.
You could try the APWI sensor, and report the results. I don't think I have heard of anyone using any thing other than Denso or the Universal Bosch. Would be nice to hear if they are comparable to the Denso.
Yeah I see what you mean, I have no idea why the shipping is so ridiculous on the Denso now, it certainly wasn't like that when I ordered mine.Last edited by TorqueEffect; 03-19-2013, 01:42 AM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Looking at AutoZone they have two Denzo. One for 13. One for 29. The one that's 29 looks to have the connectors.
Yeah, the $13 one just requires you to splice a wire into the old plug. Pretty simple stuff.Originally posted by Prafeston View PostLooking at AutoZone they have two Denzo. One for 13. One for 29. The one that's 29 looks to have the connectors.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Right on...I'll go cheap and wire my own sensor in then. Thanks!
O2 sensor is not a guaranteed fix (it's such an innocuous-looking part!) but that simple thing does signal our (90-93) primitive computers about how to optimize intake fuel mixtures. Take heart: newer cars have even more expensive O2 sensors all over the place (before the Cat, during the Cat and after the Cat etc). These items do grow 'tired', with use and over time, and replacing them once in awhile is often a good thing for both fuel economy and keeping CEL's at bay.
There have been lively discussions on this forum about which brand to buy only because no two manufacturers make 'perfect marriage' parts in this regard.
Maybe someone will chime in on which is best suited for our applications (if in fact Denso is not the specific brand we should be installing).
When looking them (O2 Sensors) up on Rockauto they do show the Denso as the OE part.
