Starting problem
  • Starting problem
    Sometimes it starts with one key turn. Other times, I must turn the ignition key on & off up to 9 times. Can always pop the clutch.
    when it DOESNT start the first time, what happens when you turn the key?
      Try spraying WD-40 or contact cleaner into the ignition key hole.
