Fog light relay whining
  • Fog light relay whining
    I recently installed 4 fog lights to one switch using a relay and fusible link. Now when I cut the car off the relay whines constantly and oscillates it's pitch with the car off. I'm fairly certain I wired it right. Does any body else have a pic of there relay setup on there fog lights or a simple diagram so I can fix this. I added the relay for safety and the inline fuse as back up. Thanks in advance for your replies.
    Sent from my HTC One VX using Tapatalk 2
    90 festy with 92 FI motor. Digital camo paint. BHAF. short throw. currently 47 MPGs
    The Pride rear fog light was used in UK and Germany only.
    Check the wiring schematic in section G for accuracy.
    Good luck.
    The wire you chose is hot at all times. It should only be hot when the car is running. You chose the wrong wire.
      helpful resource for wiring relays:
      -Zack
