Sorry for starting a new thread - I know this info is likely out there, but I'm tired & grumpy and not in a mood to do more searching :cry_smile:!
My "Meter" fuse kept blowing, so I started the fun of finding the issue. None of my cluster lights were working, nor was my fuel gage or turn signals. I studied the diagrams in my service manual and did some testing and was certain I'd figured out the problem. The black wire with a yellow strip that ran from the "Meter" fuse to the plug on the turn signal control mechanism is shorted. So, in my infinite wisdom I bypassed it and made a new jumper to run from the fuse to the plug. Now that I've put everything back together I have functioning turn signals, but none of the cluster lights or gages work.
Does the wire I jumped somehow provide power to the large round cluster plug? I can't find anything that shows this in the service manual, but after the six hours I've spent working I may very well be a combination of blind & cross-eyed!
Any help or advice would be very much appreciated!!!!
Thanks.
Thanks.
