I used the compressor most of the day last week, shut it off, and the next day it wouldn't even kick on. I got it out a couple days ago and chased power back to the motor, it's a 5hp 230v motor. I'm getting power on both legs at the motor, and continuity on all the grounds. I reset the red overload button and it will kick on, but within 20-30 seconds it kicks back off. The motor is warm to the touch but not excessively hot.
I took the motor off, took it apart and it was fairly clean, not much dust in it at all. All the wire connections look good, no broken or corroded wire contacts. Got the motor back together, and hooked it back up to power...it will run forever without a belt/load on it. I left it running for about 10 minutes and took a coffee break, came back it was still going. I changed the oil in the compressor, put the belt back on, and 20 seconds later the red overload button tripped on the side of the motor. I have to wait a few seconds to trip the reset button, but it will come back on, only builds up 10 psi or so before it kicks back off.
