Hey everybody, I've had this steering issue for almost a full year now because i just can't seem to figure out whats causing it to happen..
Here's the problem:
When i make a left hand turn, the car will start to turn smoothly, but then it suddenly jerks to the inside of the turn and i have to counter-steer a little bit to compensate for it & keep it on the road. The steering will stay in this whacky position for afew seconds after the road straightens out, then the steering wheel pops back to where it should be. When the steering wheel pops back to where it should be, this also causes the direction the car is headed in. The car makes right hand turns just fine.
I've replaced all brake components, so it's not the brakes grabbing. I replaced the passenger lower control arm and the problem got better but still not fixed, so i replaced the driver side lower control arm and after replacing that, now the problem also happens while i'm going straight down the road, usually when i hit the gas a little bit.
The car does have a bad tie rod but that shouldn't be causing this to happen right ? ( i'm waiting to fix the tie rod because i'm going to be lowering the car soon and need to wait until i do that to get the wheels aligned ) Maybe it's some kind of bushing on the strut ? thats the only other components i can think of that hold the wheels straight. A friend told me that it could be the CV axel, but that didn't sound like it could have anything to do with it to me. I know that one of my CV boots is in very bad shape.
I'm really at a loss on this repair. Any help is greatly appreciated !
Here's the problem:
