The story:
Bought a Festy for $350 about a week ago:
I pulled the valve cover and cams to clean some of the varnish and sludge off of them:
Odometer says 160k. Purchased from a teenager who had apparently learned to drive a standard on it. The kid said that the previous owner had replaced the clutch and "did it wrong, I just had to fix the clutch cable". I then drove it in third gear about 80 miles to my house, where it has remained.
The symptoms:
- 1st, 2nd and 3rd engage, but make a nasty clattering/grinding? noise, which gets louder dependent on engine load.
- The noise becomes slightly quieter if I apply pressure to the shifter.
- Neutral with clutch in makes no noise, clutch out makes an... unsettling noise.
- 4th + 5th will shift, do not engage at all.
- If I throttle up the engine with the shifter in 5th, there is a loud wheeeeow noise (which aligns with broken teeth?)
- Reverse will absolutely not shift, even with shifting from non-synchronized to synchronized gears, then into reverse. It worked once, to back it out of the parking space it was in at the beginning of the drive)
The information that I do know:
- Quart of ATF in the back of the car, along with a quart of oil and a brand-new fuel filter??
- Oil all over the sump.
- Oil all over everything, really.
- Like, actually everything:
- Also, inexplicably brand new plug wires (the grey Bosch ones?)
- Oil in the intake, the engine may have been overfilled.
- Filthy FRAM air filter.
THE QUESTION:
What do you think is wrong with the transmission, and how do I fix it?
The symptoms:
THE QUESTION:
