Well, here's some pictures of the carburetor that I took today. It's a stock carburetor. So far all I've had to replace was a fuel pump, air cleaner temp. sensor, and the pre heater hose. I'm also having a problem with oil in the air cleaner, I think it's due to a coolant temperature switch underneath the intake manifold. I plan on checking it out after I install the cat.
