checked the s/l terminals. both produce correctly with key on/ engine running. went and bought a test light. will do more troubleshooting tomorrow.
replaced the alternator today...
Use your jumper cables and jump from alt case to ground terminal then start the car to see what happens.
Lets try drivers side or passenger side, because right now all that comes to mind is the three fusible links on the drivers side.Reflex paint by Langeman...Lifted...Tow Rig
Originally posted by txranger14 View Postrandom question. what are the three posts that screw into the plate on the left side of the engine bay up top?Trees aren't kind to me...
i only ask about the solenoids because they weren't screwed in, they were all just hanging there. I feel like its the wiring harness for the s/l terminals. it's real loose and doesn't seem to stay in there at all. you can barely tug and pull it out.Last edited by txranger14; 04-14-2013, 01:39 PM.
Originally posted by txranger14 View Postok, i was wrong yesterday. both s/l terminals produce 12v when only the s terminal is supposed to. what would make it do that and what would be the effect of it?
If you plug it back in with the key on only one will have voltage. The charge light will turn back on, it would have been off with the plug unplugged.
If you start the car with everything plugged in both wires should have voltage.
What is the engine running voltage of the three wires?
What is the voltage between the alternator case and the
battery neg terminal?Last edited by Movin; 04-14-2013, 03:11 PM.Reflex paint by Langeman...Lifted...Tow Rig
ok, dad "tightened" up the s/l terminal harness, we tightened the belt pulley and got a new belt (after it broke from being too tight) and the car runs great. it was not the belt that was the source of all these problems, but after diagnostics and fixing it, its good to go again. thanks for all the helps and suggestions guys.
