I have a 1994 aspire changed everything from fuel pump to injectors and it still will not run properly can anyone help?
Aspire 1994 will not run can anyone help?
Yea but you posted in the wrong forum!2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"run properly"? doesnt' idle? wont start? has no power? need more information!!!!Trees aren't kind to me...
It will idle fine, but when I go to drive it makes it about a block and then looses power and wants to die. I have checked the cat, it is fine, replaced fuel pump, filter cleaned injectors, and put on another pressure regulator. it still does the same thing.
how did you check the cat?
have you checked the intake tube after the MAF ?
have you verified fuel pressure? (~34psi at idle and 44+ under load or with FPR vaccum hose removed)Trees aren't kind to me...
