Sup guys! so I just rebuilt my bp with a bunch of goodies. Ive been driving it for about 500miles already and today I checked the spark plugs. When I took out the spark plugs I could see the piston and on top of it was a bunch of pebble size carbon pieces(it looked like) and some oil. Is this normal? thanks
Need Help BP rebuild
Worked on Sno-Cat all day..If the piston shows no sign of washing from the rings splattering is oil from a guide blowing down over a piston. Higher rpm and heat in the combustion chamber, higher rpm pumps more oil upstairs and a bad guide and seal will allow the oil to blow over the piston during the high rpm. Cold start with thick oil will also build up upstairs and will not burn hot to make the pebbly appearance but will lay in there as wet oil.
Without a boroscope picture there are a lot of possibilities but given the information you provided ...Reflex paint by Langeman...Lifted...Tow Rig
