I have replace the fuel pump, filter, had injectors cleaned and tested, pressure regulator. The car will make it about a block before it wants to die.. Idles fine. any help would be appreciated.
Need help 1994 aspire Will Not run
Will it run normally for that "Block"? If so maybe you have contamination in the tank?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Will it sit and idle for 10-20 minutes with no problems? Can you rev it up with no missing stumbling or anything? Make sure the MAF and iat sensors are plugged in good and there's no intake leaks like FestYboy said, he knows his stuff don't take his words lightly.
Did this just start happening out of the blue or is it after some other work being done? Is there a cone filter involved?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
