There is a difference between the radiator I pulled from my 90 automatic and the one.
  • There is a difference between the radiator I pulled from my 90 automatic and the one.
    ....in my 93 manual. Whats up with that? Can I still use the 90 radiator in the 93? There are two lines coming out of the bottom of the 90 radiator that are not on the 93? Do I just plug those lines up or something? any help will be appreciated. Thanks, Jim
    Transmission cooler built into radiator is my guess. Where do the lines go to?
    93 Ford Festiva L 5 speed: In process of fixing PO's negligence
      Yup, cooler lines.
        bolt it in and dont worry about those lines if you have a manual.
          I will bolt it in and not worry about those lines. I will eat green eggs and ham.
