Not sure if this is the correct place for my questions, I will put it here since it relates to a repair issue...
I have a couple of questions that have been kicking around, i will just dump them here.
My car is an 88 and the engine has seen better days. It still runs and I intend to run it till it quits, I will do what I must to keep it running, within reason. I don't want the hassle of swapping the harness and everything to EFi on the car. I plan on staying carb and doing the weber swap while working on the engine. My concern is being unable to find a carb B3 to drop in its place.
1. If i can get a EFI B3 from a festy it should have the fuel pump lobe, correct? Will it run in a carb car, if not what needs to be done (other than bolt up my intake and carb)?
2. If i cant find a Festy B3, is there anything other than swapping the cam, rockers and intake that needs to be done to make it run in my carb festy?
I know its probably an odd question but I'm not all that familiar with carbed cars.
Thanks,
Tom
Thanks,
Tom
