Whenever I apply Trixie's brakes, sometimes it is accompanied with a popping sound coming from the rear of the car. I just recently upgraded the rear with Aspire suspension,new Aspire struts, new bearings, new brakes, etc. It's like I can hear my brake shoes engaging against the drums when I push the brake pedal. It doesn't happen always but it's fairly often.
Also, we had a pretty bad flood down here in Houston and there were a couple times where I underestimated a puddle :shock:.
Unfortunately, I work as a driver, and work has been pretty dominating lately, so I'm given very little time to repack my bearings, but I should do that pretty soon.
Also, I'm temporarily using the stock Festiva springs (might be a suspect). So overall, the suspension's on the creaky side like an old rocking chair. Have you guys had some similar problems?
. Sucks too since I still have the stock front suspension parts that I was planning to replace with aspire parts. If any of you guys happen to know anyone who has a left front aspire knuckle/hub lying around, point me to 'em.
