I have a 93 festiva with 151000 on it. Has run like a tank for the 8 years I have had it. On Monday of this week I drove home from work (about 40 miles) in the rain with no problems. Tuesday I went to start it up and the car just turned over, did not start. I have replaced the spark wires, rotor, and distributor cap. I fired it up at night and noticed that I am getting arcing across the new spark plug lines. anyone have any ideas?
Turnover but no start
When my ignition acts up I take off all the wires, take out the spark plugs. remove the distributor cap one-at-at time and wipe them clean. I also take a pair of pliers and crimp the ends of the wires a bit to ensure a good contact. When I replace the wires I put a little white grease on the distributor cap nipples to help keep out moisture. I your case I think the arching could be caused by carbon or moisture giving the current an alternate route to ground.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
did you replace the plugs too?
and did you replace everything before you had this problem, or after?
have you ever replaced the timing belt?
did you check if you had fuel pressure?
and yes even brand new wires can be bad out of the box or anything else in that manor
re:
Originally posted by WmWattWhen my ignition acts up I take off all the wires, take out the spark plugs. remove the distributor cap one-at-at time and wipe them clean. I also take a pair of pliers and crimp the ends of the wires a bit to ensure a good contact. When I replace the wires I put a little white grease on the distributor cap nipples to help keep out moisture. I your case I think the arching could be caused by carbon or moisture giving the current an alternate route to ground.
RE
Checked timing belt last night it was fine
did not check fuel pressure
The next logical step would be to see if you have spark or not.
Pull the wire from a spark plug and hold the metal contact really close to something metal while your buddy cranks the engine. That should indicate whether you have a spark.
Regards,
TimWhite '89L auto - Sold!
Silver '06 Rav4, 95k!
Hold the wire while standing on the wet ground and you'll definetly know if you have spark. Trust me you'll know.
If you have arcing or spark jumping across the wires ,you either bought the cheapest set of wires or secondary voltage is stacking up and looking for a way out .
Replace the plugs ,and get a good set of wires ,including the coil wire ,they SHOULD NOT jump spark at all .
You may have more problems than that ,but that is a start.------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Originally posted by mattswabbHold the wire while standing on the wet ground and you'll definetly know if you have spark. Trust me you'll know.
Originally posted by packrat427If you have arcing or spark jumping across the wires ,you either bought the cheapest set of wires or secondary voltage is stacking up and looking for a way out .
Same problem as,
No start or still sparking all over the place ?
If is not arcing now, and it is still a no start situation ,can you smell fuel while you are cranking it over ?------------------------------------------------
Z28 LS1 power 500 +
