Q on front wheel bearings...
  • #16
    Originally posted by FestYboy View Post
    if the spacers are NOT installed, the bearings will fail in under a week (or less).
    a thumping noise: investigate the tire first.
    I had the tires & wheels investigated. They checked out good.
    NOW I'm starting to hear grinding intermittently! :nightmare::eeeeeek:
    That's what I get for taking it to a "mechanic" friend! :nono:
    If I want something done right, I should do it myself!!hmmmmmm
    1993 Ford Festiva L blue 170,000 miles
    1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
    1995 Ford F150 XLT black 203,000 miles
    2002 Honda CRV silver 180,000 miles
    2003 Toyota Rav4 Sport black 94,000 miles
    2008 Sym Rv250 dark grey 30,000 miles. My scooter.
    1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
    Mike
    • #17
      When replacing just the rotor, do you need to remove the spacer to get the bearings out to put in the new rotor??
      Mike
      • #18
        Usually they will fail within a week.....however there are exceptions to that. I drove over two years on a set with NO spacer from a previous owner who didn't do the job correctly. How they lasted that long is anyone's guess.
        • #19
          The spacer will be exposed on the hub shaft when you pull the hub and rotor out of the spindle.
          2008 Kia Rio- new beater
          1993 Festiva- Fiona, DD
          1997 Aspire- Babyspire, DD
          1994 Aspire - Project Kiazord
          1994 Aspire- Crustyspire, RIP
          • #20
            I suffered the same thing! now i'm going to either buy the tools to do it myself or find some Rio knuckles.....
            • #21
              So you don't have to remove the spacer by itself at all?
              Mike
              • #22
                No, its pressed(the rotor) onto the hub though.Its kind of an archaic design,not meant for normal/quick rotor changes like the Aspire setup.
                • #23
                  the rotors are captured (bolted to the back side of the hub), once you knock the hub out of the knuckle, rotor replacement is only 4 bolts away (it's not pressed on the hub, but rust may require use of a hammer to knock it loose).
                  I strongly recomend that all the loose rust be knocked/brushed away before seperating the hub and knuckle so as to keep that junk off the bearings. another recomendation is to coat the knuckles with POR-15 before re-assembly. this will make things easier for service later (no heavy rust to deal with).
                  • #24
                    Well, I have repaired it.
                    What my "mechanic" friend of mine did is NOT tighten the bearings in the hub good enough. He had the spacers in there but not had tightened them properly. Damaged the racer and bearings.
                    Also the pins were coming out of the calipers and wore the brake pads uneven. I replaced them. Fixed the one bent pin and stuck codder pins in to hold them on.
                    Also he reused the old seals to where I was losing grease.
                    Runs nice now!!
                    Time for body work and rim work!! banana time lol!
                    Mike
