FINDING OIL LEAK:
1 Changed crank seal,
2 changed crank seal again because we thought it went to easy the first time,
3 check drain plug and changed oil filter (drain and refill using same oil) --- still leaking -
requesting knowledge juncture up rising:
the next step-------------- 4 changing the oil pan gasket ---HAS ANY ONE DONE THIS BEFORE? WHAT NEEDS TO BE DONE?
DOES THE MOTOR MOUNT HAVE TO BE TAKEN OFF AND RAISE THE ENGINE or CAN THE PAN BE TAKEN OUT WITHOUT
TAKING MOTOR MOUNT LOOSE AND JACKING ENGINE UP?????
(after the oil pan gasket is changed then valve cover and cam shaft seal will be in line if the oil leak is not found.
buck zeplen
buck zeplen
Me type to sloooow
