Periodic High Idle and Electrical Shutdown
  • Periodic High Idle and Electrical Shutdown
    This is what happen: Sometimes when I start my 1991 Festiva GL the engine will rev high, headlights won't turn on, the wipers won't work, the blinkers won't work. If I turn the car off and restart, everything goes right back to normal - engine falls back to normal idle and all electrical function returns. What is happening here? Thanks.
    Could it be a relay issue?
      I'm thinking may be a ground issue. Start by checking the grounds on the motor, and chassis. Theres a couple on the motor, one I remember on the right fender at the strut tower. I'd start with those. In my wiring diagrams, I don't see anyone item other than a ground that could be causing all those issues. I could be wrong, maybe someone else has had a similar issue and will join in.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        I agree with Jerry. Check for any significant resistance on your ground wires and ensure they're making solid clean contact.
        1988 Chevy Sprint Turbo 997cc
          Guess I'm the lone ranger..clean the contacts in your ignition switch. If you need info there is a thread on this with pics I need to reshoot.
            It could just be a worn ignition switch. While the motor is running and you don't have those other functions you mentioned, try turning the key just a little bit more (not enough to engage the starter) and see if you then get those functions back.
              If you suspect the ignition switch I'd spray some WD-40 or contact cleaner into the key hole before getting into taking things apart. I've dont this a couple of time when my lights and wipers wouldn't come on consistently. Works for me for 3-4 years between sprayings. Good luck.
                Thanks so much for all the suggestions! After work I'll try them out. WmWatt: What a cool trick! Thanks again everyone.
                  I love cheap and easy fixes! This'll go on my maintenance list for sure.
                    Yes, Mazda likes to run everything to ground so that they can get away with one less terminal in every relay. They have ingeniously thought of interconnecting the ground wires in a spiders web for purposes of redundancy, just in case there is any corrosion at one of the open barrel ring terminals. I doesn't hurt, every quarter century, to unscrew and clean every single ground that you can see with a Dremel mini wire brush. That will be a summer project for every single one of us.
