NGK Plug Wires question.
White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
1986 Chevrolet Sprint 1990 L Plus AutoTags: None
I have this exact part # on my Aspire. Weirdly, when I tried the little app on the parts page to see if it fits Festys, it says no. It is wrong.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I don't think so. I'll check tmw, but the coil wire they supplied isn't used for the Aspire, and I think is long enuf for the Festy.Originally posted by crazyrog17 View PostProbably a difference in coil location/wire length. The four going to the plugs might be identical.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Part #9992 is what I have. On the side of the box, it says Porche #RC-XE10.
The coil wire is TOO DANG SHORT. It needs about 2 inches (don't we all). All the other wires are wayyyy long.
So should 9786 fit? o.O
-JoeLast edited by Spike; 05-19-2013, 12:13 AM.White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
Gone:
Just checked. the 9786 coil-to-disty wire is plenty long enough; in fact it is longer than the one that's on there now, by a couple of inches. This is on a B6 swap, but for all practical purposes identical to a B3.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
BTW, the Aspire does not even use a coil-to-disty wire! I'm just using the four plug wires.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Thanks, Tom!
My wires are on order.
1988 LX 5-speed
Gone:
