I seem to need a coil for my '89 autotrans. Problem began with a hard start condition. Had to crank for several seconds before engine would catch. Replaced module in disty with a used one and car started. Hard start problem came back in a couple of days. Now, engine cranks fine but won't run. Weak yellow spark from coil wire and also from plug wire, so I assume module is still working and coil is bad. Not too many of these in jy and local parts stores would have to order one at better than 170 bucks a pop. Even Rock Auto lists it for at least $122. I have my '93 parts Festy but not sure if I want to try adapting something that might end up frying another electrical part.
Any suggestions? Thanks.
