As I had posted on here I was having issues with my 93 Festiva hard starting and random CEL generation followed by engine hesitation when the CEL cleared. After monitoring for some time, I noticed that the issue appeared only after the engine started getting warm up till normal operating temperature. Once stopping and turning the engine off, I would have difficulty in starting the car, requiring holding the accelerator all the way to the floor and after 8-10 attempts the engine would finally begin to catch acting as if it was only firing on 2-3 cylinders until finally running. Random CEL during warm up as well and as the CEL cleared, the engine would hesitate. The smell of raw fuel was always present when running at idle and would also run up the rpm randomly. Lacked power on hills (yeah I know pretty much all of cars do that! LOL) but more so then normal.
After chatting with a few friends, people at Auto Zone, and my son, who by the way is a wizard with these little cars, (but as he said, only with the carbureted engines), came up with common issue was temperature related and the only sensor that was common to the temperature issue was the coolant temperature sensor. Now my understanding as was related to me was that sensor is located under the intake manifold on the carbureted engines. So I was not eager to start this project. After checking my misplaced Festiva shop manual, found out it is actually on top and using a deep socket, 6 inch extension and ratchet, was a breeze to replace! Took me all of 15 minutes including putting my tools away! Only lost like a table spoon of coolant, replaced the washer and probe and reconnected the sensor wire and wham! Done!
Did a quick check and started right up and no hesitation, better acceleration, smoother running and right now I’m doing a gas mileage check and already seems to be better. So if you are experiencing the same symptoms, replace your coolant temperature sensor. It was $15 at Auto Zone.
