Older brother came over to help with the valve Stem seal job, but he had to leave early to pick up his son from school.
He had already put the upper intake back on before he left, so I hooked all the tubing and electrics back up.
Now it runs like complete $#!%, and doesn't idle, it lopes when given throttle.
When it does idle, it does for about 30 seconds (poorly) before the idle gets too rough and I shut the engine off.
I hold the gas steady and it will lope, classic sign of a vacuum leak.
We put the gasket for the upper intake back on, fasten down all the intake bolts and tubes so they shouldn't be leaking.
Now we did have to torque the rocker arm shafts down by feel, but we knew it was 21 ft-lb, but I don't see why that would cause it.
