Front Wheel Bearings
  • Front Wheel Bearings
    How would you check your front wheel bearings to see if they were OK and installed correctly?
    i just grab mine @ the top of the tire & pull in & out to see if there is any play. im sure there are better ways to check them but this is the only way i know how
      i use the above method to verify clamping load and then a stethescope to listen to the bearing as it turns
        You can use a screwdriver like a stethoscope. Pretty neat.
        06 Jeep Cherokee Overland
        95 Aspire (sold)
          Drive without using the brakes and feel the hub to see if it's hot. If you use the brakes that heats up the hubs too so don't.
            Drive and listen for rumble. Elevate and punch the tire, it should go thud, not rattle.
              Thanks............everything in the front end feels tight but I am still getting an increasing shake over 50mph.
                Probably tires, I have an incessant shake in ALL my cars over65/70 and everything has been replaced, ball joints, inner rod ends, racks, front and rear swaybar bushings, struts, knuckles, literally EVERY front end component. I did have one set of tires balanced but I'm thinking it was a botched job, they only charged me like $8 to balance them and the mechanic tried to lift my car from the side(where it dents/bends the rockers) until I yelled at him to lift from the crossmember, luckily I got there in time I had went to get a pop from the machine.
                I also threw one of the weights off doing 35 thru town 3 or 4 days later. I heard a ting and the vibrations got worse above 70, but it usually stops around 75/80
                2008 Kia Rio- new beater
                1993 Festiva- Fiona, DD
                1997 Aspire- Babyspire, DD
                1994 Aspire - Project Kiazord
                1994 Aspire- Crustyspire, RIP
                  One nice thing about graduating from 12 inch 'trailer tires' to quality 13 or 14s is highway travel becomes so much more smooth.
                    It's on all my cars, 12's, 13's, and 14's...but I haven't bought a new tire or had all four balanced in many many years. I only had two balanced that one time last year.
                      Try rotating the tires to see if there is any change in performance. I've swapped my front tires left-to-right a couple of times and had noises dissappear. Maybe it helps them wear more evenly?
                        Spin to check for a bent wheel. Have the tire balance guys use the fine setting. The tire weight hammer tool has a lead clipper built in to support this function.It will balance to 1/10 ounce on this setting.
