So, it is over here right now. It is a 1988 carby car. Motoxpress popped in a new engine out of a late, 91 or 93 a few weeks ago, then it came over here for a while with his son.
It developed a problem. It won't rev over 4500 RPM, and trying to climb a hill, it bucks and almost stalls. Pretty much not in any shape to drive.
First, we compared vacuum routings to another known good carby, and replaced all broken parts, and routed all the vacuum lines. One cylinder, number 2, appeared to be a little dead. Soaked it in PB blaster overnight, and now it seems to be firing again. Compression test looks pretty much 190-200 PSI across the board. Vacuum test shows it about 18 inches, with a slight fluctuation to 19 in a slow pattern. Appears OK in all other situations. New plugs, wires, and known good disty swapped in. Spark is bright blue/white at number one wire. Swapped in another known good coil for S&G's, same problem. Exhaust smells heavy of fuel, according to Zachary, I have to trust his nose, mine is clogged due to allergies. Holds idle at 650, and doesn't appear to be fouling plugs.
Thoughts?
Thoughts?
