I kinda remember seeing something on this long ago but can't find it anywhere now.
I've changed valve cover gaskets before on carb'd Festivas - no problem. But with FI I need to get the throttle body out of the way. I thought that would be easy, but Haynes suggests, altho doesn't outright say that there are water passages in the throttle body. Is that right? Can I just remove the 4 bolts/nuts that hold the TB to the intake manifold and move it enough to get the valve cover to clear? If there are water passages, is the old TB gasket reusable once I've changed the valve cover gasket??
This was the last item of the day since I thought it would be easiest. Typical!
. The only casualty of the trip was the LR tire - it picked up a roofing nail that I first heard clicking around Gnaw Bone IN (near Nashville) - didn't go flat till the next day either, another advantage of driving a light car!
