Hello everyone, I have a dilemma... my 92 Festiva dome light is not working. The weird thing is I'm getting power to the dome light assembly but it won't come on no matter where the switch is positioned. If I run a ground wire from one side of the light bulb down to the emergency brake handle the light will come on but only by doing that will it come on. How prone are these light assemblies to going bad or becoming defective? I have noticed a few on eBay for sale but haven't really wanted to spend the money they're asking for them until I know that it is in fact the assembly that is bad. Thanks in advance!
help with interior dome light
Upgrade to an Escort dome light where the ground screw is in the center. The Festiva brace holes were factory punched for an Escort dome light. Kia chose to put in a smaller, less expensive dome light that is not centered. Do a search for "Escort dome light". Good luck.
Speaking of punched center brace, I ordered one from Four Green to give me a little more stiffness in the middle of the roof. I could put in two dome lights. It would be great for someone adding a sunroof.Last edited by bravekozak; 05-28-2013, 09:31 PM.
I just upgraded to a escort light easy to do and looks great1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.
Originally posted by DaleInTN View PostHello everyone, I have a dilemma... my 92 Festiva dome light is not working. The weird thing is I'm getting power to the dome light assembly but it won't come on no matter where the switch is positioned. If I run a ground wire from one side of the light bulb down to the emergency brake handle the light will come on but only by doing that will it come on. How prone are these light assemblies to going bad or becoming defective? I have noticed a few on eBay for sale but haven't really wanted to spend the money they're asking for them until I know that it is in fact the assembly that is bad. Thanks in advance!
This in one of the most common things to fail in the Festiva. The molded plastic material that houses the switch with the little ball bearing and spring just crumbles over time.
Like everyone is saying, get an escort dome light, the one with the two map lights works great. It's really very easy to adapt it.
There is a write-up on how to do it somewhere here I believe..not much to it.Last edited by 1990new; 05-28-2013, 09:41 PM.
Here is a good example. The picture is exactly like the one that I have in my Festivas:
http://www.ebay.com/itm/INTERIOR-READING-DOME-LIGHT-GREY-91-92-93-94-95-96-FORD-ESCORT-MERCURY-TRACER-/370558870785?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item564707a501
You can probably pick up one at the junk yard cheaper though.
Originally posted by DaleInTN View PostSo, can anyone give me a year range to look for? I don't have much money and can't afford to get the wrong one.
If you are willing to wait a while, when I can afford to visit the junkyard down in Cincy, I will be grabbing as many of these as I can find. I normally sell them for $15 shipped.
All you need to do is cut the headliner a bit, and splice two wires together, and you are good.Last edited by TorqueEffect; 05-28-2013, 10:09 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Read post 33870.
Here is exactly where you have to cut the holes in your headliner.
The two holes are hidden behind the headliner.
here is the picture showing the three punched holes for mounting the Escort lamp.
Good luck Dale.Last edited by bravekozak; 05-28-2013, 10:20 PM.
please make sure your door switches are clean... they provide ground for your dome light and if they are corroded, the light becomes dim or doesn't opperate. same for that ball detent in the light housing, they are ground contacts. if that ball is dirty, you'll not have a dome light.Trees aren't kind to me...
I had the same problem, but I was able to fix it. The rivets that hold the circuits in place had loosened over the years. I figured that out by tracing the circuit with a continuity detector. So what I did was drill those out carefully, and replace them with pop rivets.
How about replacing the stock map light with a JDM Map/Dome light with built in speakers (KA8 )? They have a KA6 on the bay for $65. I am scared to think how much this puppy cost when it was listed on the bay.Last edited by bravekozak; 07-05-2013, 09:05 PM.
Originally posted by 90fastiva View PostI just upgraded to a escort light easy to do and looks great1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
I had to Google translate the Satan avatar wording a little further down past the speaker map light.
Yo soy el diablo, puedo hacer lo que quiera.
I am the devil, I can do whatever I want.Last edited by bravekozak; 07-06-2013, 06:34 AM.
