Festiva auto trans vs aspire trans
  • Festiva auto trans vs aspire trans
    Heys guys I guess I've damaged the oil pump in the transmission when I installed the transmission. Does anyone know if the aspire auto trans is compatible?
    Same trans with a higher final gear and centrifugal lockup iirc
    -Zack
      Aspire vac modulator is impossible to get new. But you can get a festy one...
      91GL BP/F3A with boost
        is it a direct bolt on or do i need aspire CV shafts and other stuff? Thanks guys...
          it is a bolt on to the engine and axles affair, BUT you may need to retain the trans mounts from the donor to be used in the festy. personaly i'd be looking for a Festy auto trans to replace the bad one, and NOT use the Aspire unit (lock up happens too soon and it kills acceleration and therefore any gas milage you may get from the lock up converter).
            Can I get one for my kids car?? Sounds like the perfect governor!! I should have figured this out years ago. Talkin of the above ^^^
