My car is a 88 Carby, 5 speed with 160K on it. I drove it home and it ran like a champ as always. I changed the rear shocks and the fuel filter and now it won't run. It started right up, but died halfway around the block when the bowl went empty. It will run if I dump gas in the carb, but not off the pump. I thought it was having a hard time priming with the pump higher than the filter. So I took the fuel line off at the carb and poured fuel through it into the pump, then I took the line off at the pump and filled the fuel filter and that line up with fuel as well. It started right up and and ran great, but died at the exact same place half way around the block.
Is it just amazing coincidence that the fuel pump decided to go bad right as I change the filter?????????
