CAR IS A MILE FROM HOME AFTER ALTERNATOR BELT DEPARTED VEHICLE. '92 Festy with AC and PS.
>>> I searched on "alternator belt," "timing belt cover," "timing belt," etc.
>>> I found nothing in the Ford official Festiva Service Manual.
>>> My Haines manual is not where I am.
I'm trying to install a new alternator belt, to replace the one which departed the vehicle on its own after squealing.
I have removed the AC+PS belt, since it blocks access to the alternator belt.
I have removed the water pump pulley.
I have removed the upper timing belt cover (four 10mm-head bolts).
The timing mark portion of the lower timing belt cover is so close to the crank pulley that I can't slip the new alternator belt in under it.
I have found and removed TWO 10mm-head bolts from the lower timing belt cover, but it's still being held on somehow.
I presume there's a 3rd (or more) 10mm-head bolts still holding the lower timing belt cover on -- WHERE IS/ARE THEY?
Why is is that I should have to remove the timing belt cover to do a simple alternator belt replacement in the first place????? Also, it's ridiculous that the AC+PS belt has to be removed to remove the alternator belt!!!!!
