The easiest way is with an easyout. Take a good center punch and put a small dent in the center of the broken bolt. Then take a small drillbit and make a hole about 1/8" hole (Try to stay as straight as possible).Take a larger drill bit and do it again.this time go a little deeper. When you get to about 1/2 the diameter of the bolt take an ez out and remove the broken bolt. Give me a PM if you need more help.
nthego:
