Caliper size bolts.
  • Caliper size bolts.
    Does anyone know the size of the caliper bolts? I'm missing the top longer one. My locale parts store can't find any that will fit since theirs are shorter. If anyone have any lying around please let me know I will buy them from you thanks.
    If it's for a Festy I have a few spares kicking around. If it's for an Aspire swap they are a bit thicker and likely achievable by scavenging from a Rio at the U-Pull. I'm going to be out of town until the weekend so don't expect a fast answer. Where are you located by the way?
      If Bert can't get them for you. I Just pulled those out the other day at the pnp and Just pocketed them.
      -James
      Est. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
        There is a chart being prepared that has all the bolt sizes, length, thread sizes and torque specs for every bolt screw and nut on a Festiva.
          take of the bolt on the other caliper and bring it to fastenal and have them order you some a grade 8 usa steel replacement bolts for both sides.
          might as well replace any other you need at the same time as well.
          maybe go stainless if you live in a corrossive place.
          if not just get the steel with zinc coating.
            Good idea except:
            Grade 8 are English thread, he will need 10.9, which is metric thread.
            But, you will not find either of those grades in Stainless.
            Stainless, though resistant to corrosion, does not have high enough tensile strength for Grade 8/10.9 classification.
              Thats interesting.
              I didn't know that. Perhaps I should have used the word equivalent in there somewhere.
              I just walk in tell them what I want and they give me the equivalent.
              I have some metric header bolts 10.9 stamped USA steel.
              Originally posted by Pu241 View Post
              Good idea except:
              ARP makes a fine line of stainless bolts that have a tensile strength of approximately 170,000 lbs per square inch. This is greater tensile strength than a grade 8 fastener.
                Yes, that is correct, but I do not see the alloy composition nor do I beleive that would you be able to order this from Fastenal to fit the festiva caliber.
                  nope you wouldnt be able to get any from fastenal agreed.
                  but for the people that speculate that stainless steel fasteners arent as strong as grade 8 myth busted.
                  now as for the characteristics of how it hardens and cools through its heat cycles and whether or not it maintains its integrity or becomes weakened is beyond me.
                  i just get steel bolts coated with zinc.
                    Rio bolts are a little different, well one of them is different, and I can't remember if it's the top or bottom.
                    2008 Kia Rio- new beater
                    1993 Festiva- Fiona, DD
                    1997 Aspire- Babyspire, DD
                    1994 Aspire - Project Kiazord
                    1994 Aspire- Crustyspire, RIP
                      I disagree, it is not speculation that in the vast majority of cases stainless steel is not strong enough for grade 8 or 10.9 specifications/applications.
                      However, and I believe this is how ARP can claim a grade 8 stainless, if you modify the steel formulation by reducing the Cr level and other alloying components, you can get a corrosion resistant metal with high tensile strength, but reduced corrosion resistance. So it is still marginally a stainless steel , but with reduced ability to resist oxidization, but higher strength and found in limited applications.
                      I'd love to have these for exhaust studs, as I already had a set through galvanic corrosion weld themselves to the block, always an issue when your from the rust belt.
                        yeah its ridiculous.
                        i like the idea of stainless
                        but am hesitant to buy any.
                        i'd almost be more willing to just replace normal steel bolts every so often.
                        i mean the header flange bolts i pulled off that were factory were still tight and new and unscrewed like they were new.
                        so i figure if they could last 18 years on my car they will last long enough for me.
                        i just dread the idea of breaking a bolt off somewhere.
                        especially somewhere critical.
                          Hey Bert I'm located in Hawaii. Don't worry we have USPS. PM me and I can pay you through pay pal or something. Thanks!
