Ok, I have been bashing my head for two weeks over this. I finally picked up two dimmers at the junkyard, tried both of them, one was obviously bad since it started smoking, but the other one didn't smoke but still didn't kick on the dash lights.
I have tested the hot wires on the dimmer, and they both read 12volts, and the ground for the dimmer is just fine. I test the illumination wires at the connector behind the cluster, both the wires read 12volts.
Also threw my non-tach cluster in there, still no dash lights. So it SHOULD BE $%#$ing working! Especially when the wires AT THE CLUSTER read 12v, but they refuse to turn on.
The only thing I can think of is that the Festiva system works like christmas tree lights, if one bulb goes out, the entire system of lights go out.
