how to get the bottom bolt off water pipe on water pump on A/C equipped car?
  • how to get the bottom bolt off water pipe on water pump on A/C equipped car?
    Im getting ready to unhook the compressor and drop the bracket after I swap the crank seal. I'll check back here before then to see if there's an easier way.
    Apparently you just take the idler bracket off. The dipstick tube doesn't make it easy to get to still....
