i am having trouble setting the timing on my 1993 Festiva. it has a new distributor on it. i know the rotor is in the right spot because it can only go three ways. i have it turned to where the car runs, the other two rotations the car wont run. i have a brand new timing light from sears. now on the crankshaft pulley there are two marks. on the timing marker scale thingy there is one dash with a big T and then just above that there's a big dash with 10. i hooked the timing light to cylinder number one spark wire- the one on the left side looking at it... problem is that the timing marks dont match up when i have the car running. no matter how much i turn the distributor the marks wont line up. any suggestions? could the crank pulley be not installed properly?
thanks,
-Brian
thanks,
-Brian
