ok, i have a 88 problematic festiva.
heres the long saga....
I drove it through a puddle which turned out to be more like a river.
it sucked in water and blew the head gasket.
When i finally went to change it i planed the head and did everything correctly. but was still leaking coolant into oil. I then retryed it again two more times, using indian head gasket sealant and copper gasket spray. but still leaked.
i gave up on it for about half a year, and now i decided to try it again but this time im using copper permatex in addition to the head gasket and torqued everything down right... Now, NO more leak.
the new problem:
it idles fine,(a little high) but it sounds healthy, then when i give it gas its just has sparks arching all around the coil. ive already replaced the cap and rotor last year and only got like 500 miles on it before the car just sat. I have new spark plug wires. i took off the coil cleaned the terminals, checked the spark plugs.
the spark is sparking from the negative connection on the coil around the center piece and sparking against the positive side, and no matter what i do to tape it up or put rubber around it, it doesnt stop. Is the coil bad possibly? or i was thinking maybe when i took the head off i got some oil drippin into the disty cap. any ideas?
the new problem:
