I just did my suspension swap to my 91' manual trans. Fest. I used Aspire everything in the rear (no problems there). And used the aspire brakes wheel assembly and shocks/springs. The sway bar and control arms are from the Fest. The problem seems to be in the driverside CV shaft (short shaft) almost like the shaft is being torqued too far down. when i spin the wheel it hits/stops. I looked at the inside knuckle and everything seems to be in order. Has anyone had this problem or have a solution to what i may have done wrong?
I hope i posted this in the correct place.
